Need help - looking for monitor
atreyurock
I need some help in looking for a monitor. It’s going to be used for gaming and watching movies. And it’s going to be powered be a HD3850. Can any of you suggest a monitor that will work for me? Preferably around a 19inch’s and nothing higher than a 22inch. My price range is $200-250. I was looking at some Dells, HP’s, BenQ, and some Samsungs but I don’t know which is better to go with. So if you have any suggestions, I gladly listen. Thank you for your time
Go for a benq. All of their screens have a VGA and a DVI-D Input. I have a 19" inch screen and it is fantatstic for watching movies off. But you can also go for the bigger ones.
What sort of price rang are you looking at????
The screen looks good.
Well i'm just using the graphic card on my motherboard.
My Screen is a:
Benq FP9VV 19" Inch
My Brother's is - the one with Speakers
Benq T9W 19" Inch
The new model has built in speakers.
I'm not sure if you can get them any more.
