need help on motherboard info
kefflon
Hi! I bought a EPoX EP-8K9A9I mother board with amd socket A-(462) . What processors can I use? And how much RAM can I put in the 4 slots?
Any particular reason why you bought a very outdated motherboard and asking what processor and memory can go in it? Unless you had all the parts from a different motherboard then buying that board was a mistake. You should have bought an updated board.
Thank you guys!
The reason I bought an old board is I got a computer case and 3 fans from a friend and wanted to see if I can build a working PC really cheap. I mean one that you can still properly surf on, but where the parts cost like nothing.
What is the best thing to do? To buy a new motherboard and the rest second hand?
If I can have 2 or more gig and a graphic card with this board, wont it be enough to surf and run some other programs?
Thank you guys!
If you want it cheap. Ask some computer greek to donate something to you...
Anyway, your component could be cheap, but not obsolete.
