scouter111
does anyone know how to set up a external hard drive and add it to a network thu a windows pc but i have a mac i wish to use it with also?
I dont knwo macs very well but uh .. plug it in? If Macs support DHCP and the TCP/IP protocol you should be finehow would you get the mac and windows machines networked with the router?
i tried the software and I cant not get it to work it keeps saying it is the wrong password so is there any othere software you know of?
Ok so lemme get this straight:ok thanks, but when I set it up I still cant access the hard drive to password is off and the domain is on the internet but no off my computers can find it
Of course you can always lock down with OTP and IP restrictions(otherwise you're going to be broadcasting your FTP service to the outside internet if you've got FTP service enabled through your router).
