Hi there,
In order to turn my Bell satellite receiver into a PVR, I need an external hard drive with the following criteria (according to the Bell website):
7200 RPM rotation speed
between 50mb and 2tb capacity
holds a single hard drive (enclosures holding two discs are not supported)
plugs into AC power outlet
has a USB 2.0 connection
has no sleep mode (cannot power down when idle)
I don't know anything about external hard drives so I thought I'd go to bestbuy.ca and read the specs. Unfortunately, they don't all report the rotation speed (whatever that is), don't say whether or not they connect to an AC power outlet, and don't say if they have a sleep mode.
Can someone suggest which one to buy? I'm in Canada so bestbuy.ca or amazon.ca is fine. I don't need/can't afford the most expensive ones! I just need a basic one.
Thanks so much!
P.S. Here is the link that tells me what to get: http://support.bell.ca/TV/Receivers/How_to_turn_my_Bell_HD_receiver_into_a_PVR#displayStep
I have the 6131 receiver.
Thanks so much!
