Need help, problem caused by virus.
dunerider5
I had some sort of virus or something, Buzz had me install and run FixWareout to fix it. It did fix most of the problem, but there is still one thing. When I try to ping any ip address in a command prompt, even my own ip, I get an error message that says C:\Windows\system32\ping.com is not a valid Win32 application. In the command prompt it says access is denied. It never used to do this.
This was the old problem. http://computerforum.com/showthread.php?t=38251
Copy and past this in your runbox sfc /scannow you might have to install your windows cd. This will search for any missing or corrupt windows files, maybe one of them got deleted because of the fix somehow. If all the files are good then it's going to be some kind of configuration issue causing this problem.
