Roguecat911
Need help with Catalyst+graphics card drivers
Ok here is the scoop. My friend wanted a new PC and was gonna get a Dell. I told him no he was gonna build his own machine for the same price but better. So i went on newegg and put together a PC for him and he ordered it. I went over to his house last night to put it together and we ran into a problem. Here are the parts he ordered:
Mobo: ASUS M2R32-MVP Socket AM2 AMD 580X CrossFire ATX AMD Motherboard
Vid card: GECUBE HD2900XT-VIE3 Radeon HD 2900XT 512MB 512-bit GDDR3 PCI Express x16 VIVO HDCP Video Card
Processor: AMD Athlon 64 FX-62 Windsor 2.8GHz 2 x 1MB L2 Cache Socket AM2 Dual Core Processor
RAM: Patriot eXtreme Performance 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
FDD: Rosewill RCR-FD200 All-in-one USB 2.0 Black 3.5" Card Reader with 1.44MB Floppy Drive
CD/DVD Drive: LG Electronics LG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 18X DVD±R DVD Burner with LightScribe
HDD: Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
Well we got everything in and put together and we hooked everything up to the mobo and the power supply and it looked good but when we plugged the monitor and a keyboard to it and powered it up nothing would display on the screen. There was no BIOS options or nothing it just was blank. I figured you know it wouldn't boot obviously since he had no OS on it but i thought the least it would do would allow me to get to the BIOS and make sure everything was there but it wouldn't.
SO i had a few ideas that i think might work but i'm leary to try them in case i ruin something. What i believe to be the problem is that since it is a new HDD and mobo with no OS or onboard graphics that it isn't recognizing the video card there for no display. My idea to fix that is that i would put hook the HDD up to my mobo and load XP on it and then install the drivers for the video card and then put the card and the HDD back into his machine. Would this process work or is it a dud idea? I'm open for suggestion/information on how to fix this problem i don't want to ruin my friend computer so any would be great.
Thanks you for your time.
