F frummaceuk New Member Mar 18, 2009 #1 I bought a new computer and there is a cpu temp sensor coming from the front of the case. Where does this go?
Backwoods166 New Member Mar 21, 2009 #2 I would check your mobos user manual for a map of all plugs. Also, try the manual for the case, try the manufacturers website, and try google if all else fails. Info we would need to help is make/model of case and mobo.
Aastii VIP Member Mar 21, 2009 #3 Are you building the system or are you just curious? I'm a little confused about the post
