Hi, going to make it short, I'm building or replacing nearly all components in my old PC, scraping every part besides the case and the storage lol. I've put together a new build the past few days and wondering if I can pull the trigger without running into ANY issues. Please be harsh and give your opinion on any and every dynamic of the proposed build, if there are cheaper options with equal or better performance, let me know. I'm not super experienced when it comes to this sort of thing so if you notice any complications regarding clearance especially of CPU cooler and ram or that my motherboard is shit or that I should buy a prebuilt with the similar specs for cheaper, please tell me. Thank you
https://pcpartpicker.com/user/rjd3_/saved/fZ4QRB
Intel Core i5-13600K 3.5 GHz 14-Core Processor
Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler
ASRock Z790 Pro RS ATX LGA1700 Motherboard
TEAMGROUP T-Create Classic 32 GB (2 x 16 GB) DDR5-6000 CL48 Memory
Crucial MX500 500 GB 2.5" Solid State Drive
Zotac GAMING Twin Edge OC GeForce RTX 4070 SUPER 12 GB Video Card
Cooler Master MasterBox MB511 RGB ATX Mid Tower Case
Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply
I also have two (2) notes on PCPartPicker that l need opinions on:
Note: The Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler may require a separately available mounting adapter to fit the ASRock Z790 Pro RS ATX LGA1700 Motherboard.
Note: The video card PCIe 16-pin power connector adapter is being supplied by three 6+2-pin power connectors. Please ensure that the three 6+2-pin power connectors are not daisy-chained and do not share the same power cable.
