Netbook freeze when battery plug in. Please help
paulcheung
Hi all,
we have this MSI U100 Netbook keeping freeze, When I tookout the battery and run on adapter alone it would stop freeze. Once I put back the battery it start freeze again.
Any one know what could cause this?
Thank you.
Looked up the MSI U100, and it appears to be a fairly old model, as far as netbooks go (please correct me if I am mistaken). As a result of age, could the battery be completely shot due to age, and it somehow causes this problem?
That was also my first thought, the battery is probably dieing. But if the laptop runs for a bit with the battery in, check the battery levels, boot up and go into BIOS and stay there, with the battery inside, and see if it still freezes. It's probably a bad battery though.
The netbook is not one year old yet. I don't know what cause the problem, but I have change the power setting to never turn off any thing at all on battery. it stop freeze. but it shouldn't set for that. well that have to do for now.
Thanks ,
