Hey! I recently built a computer and I am having some issues with it. Whenever I turn it on, some lights turn on but not all of them. (Some cosmetic lights on the motherboard do not turn on) And the computer restarts every so often (as in some lights shut off and the fans stop running then they turn back on again). In addition to this, whenever I plug in a monitor that I know works, the monitor turns on then says no signal. All of the plugs are plugged in tight so I don't know whats wrong with it. Oh and the LED light for DRAM is on solid red, so maybe it's a RAM issue. Additionally, one time when it restarted, more lights were on than before when it turned back on (cosmetic lights for the motherboard that is). Here are my specs:
RAM: HyperX Fury 32GB 2666MHz DDR4 CL16 DIMM (Kit of 2) Black XMP Desktop Memory HX426C16FB3K2/32
Motherboard: Gigabyte Z390 AORUS PRO (Intel LGA1151/Z390/ATX/2xM.2 Thermal Guard/Realtek ALC1220/RGB Fusion/Gaming Motherboard)
Case: NZXT H710 - CA-H710B-B1 - ATX Mid Tower PC Gaming Case - Front I/O USB Type-C Port - Quick-Release Tempered Glass Side Panel - Cable Management System - Water-Cooling Ready - Black
GPU: ZOTAC GAMING GeForce RTX 2070 SUPER Twin Fan 8GB GDDR6 256-bit 14Gbps Gaming Graphics Card, IceStorm 2.0, Spectra Lighting, ZT-T20710F-10P
Processor: Intel Core i7-9700K Desktop Processor 8 Cores up to 4.9 GHz Turbo unlocked LGA1151 300 Series 95W
Cooling: NZXT RL-KRX52-02 Kraken X52 240mm All-in-one Water / Liquid CPU Cooling with Software Controlled RGB Lighting
Power Supply Corsair CX Series 650 Watt 80 Plus Bronze Certified Modular Power Supply (CP-9020103-NA)
Storage: 1 TB hard drive
Pictures of my computer and the DRAM light are attached
Thanks for reading, any help would be appreciated.
I'm pretty sure that it is not an overheating issue as everything is cool and the computer was brand new when it was restarting
Oh and I have tried removing the GPU and plugging my monitor into my motherboard but the monitor still says no signal.
