not sure whats going on...need little help please
jhooga
so Im working on this computer a friend gave to me and it freezes at loadup it freezes on the windows logo, this is running win 7 btw, i ran a chkdsk on it and it found errors and fixed them it said, I have pulled the drive hooked it up via usb to my desktop and ran malwarebytes and found nothing there, it boots up in safe mode no problems ( i am on it right now actually) but still freezes on normal mode, any ideas??
its more than just a restart for this one, believe me ive tried a few times a few different things, even tried throwing the win 7 disc in and hitting repair this install and nothing worked for that either
Have you tried removing one of the RAM sticks? Do a trial and error test one the RAM and see if this solves anything.
so i removed one of the RAM sticks and it booted up fine little slow so i put the RAM back in and it booted up fine, does this sound like it would be a typical issue for that to happen?
Are you in normal mode now or still in safe mode? Lets see if there is any infections in play.
Download and Run ComboFix
If you already have Combofix, please delete this copy and download it again as it's being updated regularly.
Note: Do not mouseclick combofix's window whilst it's running. That may cause it to stall
Combofix should never take more that 20 minutes including the reboot if malware is detected.
In your next reply please post:
  • The ComboFix log
  • A fresh HiJackThis log
  • An update on how your computer is running
It could have been the RAM not seated all the way, causing a short...Which would then cause the freeze and a BSOD. :D
ComboFix Log
ComboFix 11-04-07.07 - Laptop 04/07/2011 19:50:37.1.2 - x64
Microsoft Windows 7 Ultimate N 6.1.7600.0.1252.1.1033.18.3032.1983 [GMT -7:00]
Running from: c:\users\Laptop\Desktop\ComboFix.exe
AV: Microsoft Security Essentials *Disabled/Updated* {108DAC43-C256-20B7-BB05-914135DA5160}
SP: Microsoft Security Essentials *Disabled/Updated* {ABEC4DA7-E46C-2F39-81B5-AA334E5D1BDD}
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
((((((((((((((((((((((((( Files Created from 2011-03-08 to 2011-04-08 )))))))))))))))))))))))))))))))
2011-04-08 02:54 . 2011-04-08 02:54 -------- d-----w- c:\users\Default\AppData\Local\temp
2011-04-08 02:21 . 2011-04-08 02:21 -------- d-----w- c:\users\Laptop\AppData\Roaming\Malwarebytes
2011-04-08 02:21 . 2011-04-08 02:21 -------- d-----w- c:\programdata\Malwarebytes
2011-04-08 02:21 . 2010-12-21 01:09 38224 ----a-w- c:\windows\SysWow64\drivers\mbamswissarmy.sys
2011-04-08 02:21 . 2011-04-08 02:21 -------- d-----w- c:\program files (x86)\Malwarebytes' Anti-Malware
2011-04-08 02:21 . 2010-12-21 01:08 24152 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-04-07 01:01 . 2011-04-07 01:01 -------- d-----w- C:\found.000
2011-04-05 19:25 . 2011-03-15 05:17 8424784 ----a-w- c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\{D5EB818D-4236-48A4-9754-FCD53E6336AE}\mpengine.dll
2011-04-05 08:33 . 2011-02-11 04:06 601424 ----a-w- c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\{7ED5A1D6-786A-4ACE-B9D4-F70CC3299D4D}\gapaengine.dll
2011-03-25 06:14 . 2011-02-11 04:06 601424 ----a-w- c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\NISBackup\gapaengine.dll
2011-03-22 01:42 . 2011-03-22 01:44 -------- d-----w- c:\users\Laptop\AppData\Roaming\U3
2011-03-21 23:07 . 2011-03-21 23:07 -------- d-----w- c:\users\Laptop\AppData\Local\GameHouse
2011-03-21 23:07 . 2011-03-21 23:07 -------- d-----w- c:\programdata\Trymedia
2011-03-21 23:06 . 2011-03-21 23:07 1139514 ----a-w- c:\windows\Bejeweled 3 Uninstaller.exe
2011-03-21 23:06 . 2011-03-21 23:06 -------- d-----w- c:\program files\Games-Full.info
2011-03-13 07:54 . 2011-03-13 07:55 -------- d-----w- c:\program files (x86)\VirtualDJ
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2011-03-15 05:17 . 2011-02-11 04:07 8424784 ----a-w- c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
2011-03-03 19:56 . 2011-03-03 19:56 472808 ----a-w- c:\windows\SysWow64\deployJava1.dll
2011-02-19 06:37 . 2011-03-09 00:08 1135104 ----a-w- c:\windows\system32\FntCache.dll
2011-02-19 06:37 . 2011-03-09 00:08 1540608 ----a-w- c:\windows\system32\DWrite.dll
2011-02-19 06:36 . 2011-03-09 00:08 902656 ----a-w- c:\windows\system32\d2d1.dll
2011-02-19 05:32 . 2011-03-09 00:08 1074176 ----a-w- c:\windows\SysWow64\DWrite.dll
2011-02-19 05:32 . 2011-03-09 00:08 739840 ----a-w- c:\windows\SysWow64\d2d1.dll
2011-01-26 06:53 . 2011-02-12 03:21 982912 ----a-w- c:\windows\system32\drivers\dxgkrnl.sys
2011-01-26 06:53 . 2011-02-12 03:21 265088 ----a-w- c:\windows\system32\drivers\dxgmms1.sys
2011-01-26 06:31 . 2011-02-12 03:21 144384 ----a-w- c:\windows\system32\cdd.dll
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"Google Update"="c:\users\Laptop\AppData\Local\Google\Update\GoogleUpdate.exe" [2011-02-12 136176]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"GrooveMonitor"="c:\program files (x86)\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"Adobe Reader Speed Launcher"="c:\program files (x86)\Adobe\Reader 10.0\Reader\Reader_sl.exe" [2011-01-30 35736]
"Adobe ARM"="c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-11-10 932288]
"QuickTime Task"="c:\program files (x86)\QuickTime\QTTask.exe" [2010-11-30 421888]
"iTunesHelper"="c:\program files (x86)\iTunes\iTunesHelper.exe" [2011-01-25 421160]
"SunJavaUpdateSched"="c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2010-05-14 248552]
c:\users\Laptop\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Adobe Gamma.lnk - c:\program files (x86)\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2005-3-16 113664]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
"ConsentPromptBehaviorUser"= 3 (0x3)
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MsMpSvc]
@="Service"
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R3 dc3d;MS Hardware Device Detection Driver;c:\windows\system32\DRIVERS\dc3d.sys [x]
R3 NisDrv;Microsoft Network Inspection System;c:\windows\system32\DRIVERS\NisDrvWFP.sys [x]
R3 NisSrv;Microsoft Network Inspection;c:\program files\Microsoft Security Client\Antimalware\NisSrv.exe [2010-11-11 282616]
R3 Point64;Microsoft IntelliPoint Filter Driver;c:\windows\system32\DRIVERS\point64.sys [x]
R3 USBAAPL64;Apple Mobile USB Driver;c:\windows\system32\Drivers\usbaapl64.sys [x]
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [x]
R3 WDC_SAM;WD SCSI Pass Thru driver;c:\windows\system32\DRIVERS\wdcsam64.sys [x]
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [x]
S3 MpNWMon;Microsoft Malware Protection Network Driver;c:\windows\system32\DRIVERS\MpNWMon.sys [x]
S3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\DRIVERS\yk62x64.sys [x]
Contents of the 'Scheduled Tasks' folder
2011-04-05 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1766500449-2068980675-317588264-1000Core.job
- c:\users\Laptop\AppData\Local\Google\Update\GoogleUpdate.exe [2011-02-12 04:24]
2011-04-08 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1766500449-2068980675-317588264-1000UA.job
--------- x86-64 -----------
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2010-08-26 161304]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2010-08-26 386584]
"Persistence"="c:\windows\system32\igfxpers.exe" [2010-08-26 415256]
"MSC"="c:\program files\Microsoft Security Client\msseces.exe" [2010-11-30 1436224]
"IntelliPoint"="c:\program files\Microsoft IntelliPoint\ipoint.exe" [2010-07-22 2327952]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"LoadAppInit_DLLs"=0x0
------- Supplementary Scan -------
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
uInternet Settings,ProxyOverride = *.local
IE: E&xport to Microsoft Excel - c:\progra~2\MICROS~2\Office12\EXCEL.EXE/3000
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10n_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10n_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
@="{FAB3E735-69C7-453B-A446-B6823C6DF1C9}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10n.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.10"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10n.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
Completion time: 2011-04-07 19:55:56
ComboFix-quarantined-files.txt 2011-04-08 02:55
Pre-Run: 226,200,604,672 bytes free
Post-Run: 226,728,882,176 bytes free
- - End Of File - - F8C4B245011FF0B5C1DA789897FD1FE1
Hijack This
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 7:57:26 PM, on 4/7/2011
Platform: Windows 7 (WinNT 6.00.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16722)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\iTunes\iTunesHelper.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil10n_ActiveX.exe
C:\Program Files (x86)\Internet Explorer\iexplore.exe
C:\Users\Laptop\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\S7L7KF2Q\HijackThis[1].exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 10.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKCU\..\Run: [Google Update] "C:\Users\Laptop\AppData\Local\Google\Update\GoogleUpdate.exe" /c
O4 - Startup: Adobe Gamma.lnk = C:\Program Files (x86)\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\Office12\REFIEBAR.DLL
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveSystemServices.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files (x86)\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
End of file - 6399 bytes
It doesnt seem to be doing too bad at the moment im about to attemt turning it off and seeing if it boots up properly right now
Yeah, I don't see any issues there. You may want to run the hard drive manufacturers disk diagnostic utility to make sure all the errors are gone. The manufacturers utility actually is a better program to use. Make sure you run the extended test.
