dsgill_tigris
Hi guys,
I have an NZXT Sentry LX LCD Fan Controller. The probelm is that i am worried that i did not set up the fans of my case correctly, and i think i dont have my temperature sensors of the sentry put at the correct places. So i was hoping if you guys can help and tell me how the fans should work as (like intake or exhaust) and where to put them for best cooling and airflow. Also it will be great if someone can tell me where to put this temperature sensors...and if someone does not use the automatic function but the manual - so what rates should the fans work. And one more thing...what are the fans that i should connect the NZXT Sentry LX Fan Controller too? Well thanks alot guys...i just want the best airflow and the best cooling i can get with this.
By the way here is some information of my computer if you need it:
Mainboard: M3N72-D
Processor: AMD Phenom X4 9850 Black Edition at 2.5 Ghz
Memory: 4gb DDR2 Ram and Hard Drive: 500gb
Video Card: ATI Radeon HD4850
Power Supply: Corsair TX650 Watt (it's at the bottom of the case)
Case: Coolermaster HAF 932 Full Tower.
I have a big exhaust fan on top, an exhaust fan in the back/rear, a big intake fan in the front (bottom), and a big intake fan on the side panel.
THANKS!!!
Mainboard: M3N72-D
THANKS!!!
