Ok, new build turns on and the power led blinks red twice.
Pelagic Argosy
The fans on the case, graphics card and processor all work. There is no input on the monitor. I was slightly flummoxed by the PSU connections and the sata installation and I have no idea how to make sure the set up is correct. The keyboard blinks when the I/0 switch at the back is turns on. I also have a split psu cable with two heads, one labelled cpu1 and the other cpu2. There is only one slot that fits either head.
Specs:
Asus M2N32-SLi-DLX nForce 590 SLi (Socket AM2) PCI-Express DDR2 Motherboard (MB-142-AS)
OCZ 2GB (2 x 1GB) PC5400 Dual Channel Gold GX XTC Series HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express)
AMD Athlon 64 X2 Dual Core 4200+ 2.20GHz (Socket AM2)
Akasa AK-P050FG8-BKUK 500W Green Power 80+
Samsung SH-S162L 16x16 DVD±RW Dual Layer LightScribe
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
hermaltake VA3000BNA Tsunami Dream SuperMidi Aluminium Tower - Black (CA-012-TT)
Ok, I figured out that the cpu1 head needs to be plugged in.
There's still no display. There is a green LED on on the motherboard. I can't figure out whether the gfx card is the problem as my current pc is too old for it. Same with the ram.
This is my first build and I'm terrified that I've bricked it somehow.
