linkin
Okay, my dad is having a problem with his old sony vaio. model number is PCG-GRT30P. It's a pentium 4 desktop replacement.
The wireless is dead. drivers are installed but it won't work. latest sony ones have been installed, it gets a "code 10 - the device cannot start" error with any version of the drivers. The wireless actually has a switch, which was on when we tried to use the wireless on it. no go. We even took apart the laptop to see if the connection had fallen out or something but we couldn't find it anywhere. laptops are a bitch to take apart.
Is it possible the wireless hardware has failed? and is it fixable?
The laptop also has a bad battery (holds little/no charge) and when unplugged the display goes funky, most likely because of some power saving setting somewhere.
Also, the function keys, well, no longer function. the laptop screen is very bright and we can't adjust it now.
Can anyone help?
Can anyone help?
