Overclocking Parts?
repo485
I am looking to build a desktop computer from newegg.com and don't have an outrageous amount of money. My budget is about $1200 with at least with a nice 22" widescreen monitor if possible. The thing i need from you guys is parts you recommend that are easy to overclock because I'm not a computer genius but I kinda know what I'm doing. I need all parts to fully build this computer. Good luck and thanks for helping!
ok Overclocking CPU intel E21xx.
ram Crucial Ballistix PC2-8000 2 GB
this runs at 1000MHz normaly so it will be safer to OC with an looking at about 20 diffrent ram chips this seems to be the best Crucial Ballistix PC2-8000 2 GB
this shows OC capability http://www.hardware.info/en-US/prod...ucial_Ballistix_PC28000_2_GB_BL2K12864AA1005/
an some other ram chips OCing capability http://www.hardware.info/en-US/productdb/bGRkZJg/ZGJnmWZmyZ9l/ZGhnnWZsyQ/viewbyspec/
now MOBO
P35-DS4 i hav heard is good for OCing
Case antec 900 or a one of these
i have these one it is a great case an very very cool 120mm rear u can put 1 at the front the side ontop of CPU an a nother on the side ontop of GPU
http://www.thermaltake.com/product/Chassis/fulltower/sopranoRS100/vg6000bws.asp
in fact most of these cases are alrite
Why go with such a low ended CPU? A 22" wide screen monitor costs less than $300, leaving about $900 for the rest of the computer.
@repo485: Do you plan to play games with the computer? If so, I would go with a 8800GT, 2 gigs of ram (or 4 if you want to), and a E6750.
well what are the best parts for ocing and INTENSE multitasking.. I plan to play some video games too(crysis, age of empires 3...etc) i dont want any lag please! Possibly 64 bit?
MOBO $199
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128080
CPU $244.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
Ram get 2 of these $135.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146725
HDD $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136178
GPU $249.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133205
that is a total of $929.95 all good OCing parts.
all u have do do is get a case an PSU i recemend for the case an antec 900 or a full tower thermaltake an the PSU i would get a 700W or bigger good luck
