Parts for build I'm Planning to buy in a week and a half, please advice
Looks a really good balanced build but id consider looking into the h100i GTX if its anything like the H110i gt i used to have it could only support 2 fans if you plan on push/pull.
Id also drop the noctua industrial, the fans are loud enough as they are and the industrial ones will be like leaf blowers and will give you a few degrees over the stock ones, the stock ones are really good fans.
id maybe consider a full tower case aswell if you can especially for 2x 980Ti's I used to have the MSI 980Ti's but they just got to hot for my liking 80c+. So look into the Gigabyte G1 or zotac Amp with 3 fans as they will provide better cooling.
1600w is too large of a PSU id get 1000w for that build or if you plan to upgrade in the future get a 1200w but 1600w would be for quad SLI systems and not needed for your build.
Unless you have a need for 64gb memory which i doubt, id drop it to 16gb. What do you plan to use the system for?
Id suggest this build:-
http://pcpartpicker.com/p/tt4zLk
