PC won't start, possible motherboard problem?
silveraden
Yesterday, I added another 512 memory module to my current 512. After I inserted the card, I started my PC and after 30 minutes of browsing, my PC shut down and not starting back again. When I press the power button, the sound goes.... tooooooooooot...... tooooooooooooot...... tooooooooooooot..
I brought it to nearest PC repair shop and the technician told me the problem is motherboard.... Any idea if he is correct? I am using my laptop right now and I can't afford to lose all content of my desktop.. thanks
What model is your Motherboard, if you get a Manuel it tells you that the beeps mean
I think its Jetway PM2M/PM2M2. It's an old computer. Got it last 2004 but I can't throw it away because of very important software installed... It still doing good until last night...
well the beep codes for that board are...
Long beeps in an endless loop: No DRAM install or detected
One long beep followed by three short
beeps :Video card not found or video card memory
bad
High frequency beeps when system is
working :CPU overheated
System running at a lower frequency
Remove both memory stick from the motherboard and boot up, with no memory.
If you still get the 3 beeps then the motherboard is dead.
Also try resetting the BIOS.
