dat1baller
"The filename, directory name, or volume label syntax is incorrect."
I just bought this external firewire harddrive. I recorded a song for a client. I went to burn the file in Nero. Inside Nero I decided to change the name of the folder it was in. Now I can NOT open the folder and the file names changed. The files are now named:
q4
o
r4
q4f
etc.
and if I try to open the folder I get this:
W:\q4[] is not accessible.
The drive is formatted in Fat32, but my PC is NTFS internally.
Win XP Pro
Maxtor External Firewire 500GB drive
Also when I turned the harddrive off and turned it back on, the partition names all changed to "Local Disk".
PLEASE HELP ME RETRIEVE THE DATA!
Thank you in advance,
Michael
q4
o
r4
q4f
etc.
Win XP Pro
Michael
