chrisfreez
I have the full version of XP with SP2. i had some problems and tried to format the c drive and the system would allow me. So I loaded the XP/SP2 from the OS disk. it loaded the XP os and it works fine, but there is only 5 GB out of 40 So I have to format the c drive and reinstall the OS.
What do I have to do to format the C drive. Over the years, i use to format my c drive whenever necessary because of problems.
What do I have to do to format the c drive with Windows XP/SP2?
When I relaoded XP it must have installed it next to the one that is already on the drive becasue I only have 5 GB left. Before I reinstalled XP from the Windows XP/SP2 CD I had 16 GB left out of 40. So all the old stuff must still be on there but it does not show up on the screen.
Here is the Message I got..." Windows cannot format this drive. Quit any disk utilities or other programs that yoiu are using." I had nothing running at the time.
I tried to format the c drive form the c drive icon that comes up when you click the right mouse button on th "C" drive icon.
Thanks for any help
Thanks for any help
