I am currently using ATT&T for my internet service. A little over a month ago, my service became sporadic at best causing the router to reboot every few minutes. The service would return after about a minute. I've called AT&T several times and talked to their tech people. They tried resetting the modem 3 times before a tech was sent out to check the line. The tech checked the line and fixed 3 problems but the problem is still happening. AT&T finally sent out a tech to check my system and gave me a new 2wire modem. My problem persists as the new modem isn't solving the problem. I talked to the tech while he was at my place and the problem continued. He seemed to think it was a grounding issue but I tried moving the modem to a direct grounding plug. The problem is still rearing it's ugly head.
Right now, I am using two laptops on the line. One has XP and the other has Win7 on running. My old modem was a 2wire 1701G and the new one is also a 2wire. Any ideas on what can be done other than complaining to AT&T again? Thanks in advance.
