Just finished putting my new build together 30 minutes ago. Specs are:
MSi 940A-G45 MB
Phenom II X4 960t CPU
16 GB RIPJAWS PC 12500 1600 RAM
Nvidia GForce n520 GPU
Rocketfish 800 Watt PSU
Corsair H60 Liquid Cooler
I have everything assembled properly. The case wires were connected to the motherboard properly (White = Negative). Power supply connected properly. RAM seated. CPU and cooler installed properly.
When I attempted to turn on by pressing the Power Button nothing happened. Dead. So, I removed the Power LED, Reset SW, HDD LED and tried with just the POWER SW. Still nothing. Turned the PS around and pressed the power button and the only thing that came on was the WD Mybook that I have connected to the desktop. Nothing else, no BIOS, nothing. Took all the RAM out and tested, nothing, no beeps, same issue so I dont think its the RAM. The fans are not even turning.
What should I try or what can I do to test?
			MSi 940A-G45 MB
