Hello! I want to connect my third monitor to my computer and I bought a adapter so I could do that. But now the screen just says "Power Saving Mode" and turns black. What should I do? I tryed to connect another of my screens with the same cable and then the other screen says "check the signal cable". The adapter I'm using is called "DVI-D DualLink". Is it to the monitor, computer, adapter or something else? My GPU is "GeForce GTX 750 Ti"
