Power supply help, 12v Rails are pissing me off! I got 6!!
xXxRuinationxXx
ok
so yea you can see my pc from my other post
I'm running tri sli 512 ddr3 9800 black edition pci-ex's
requiring 26a on the 12 v rails
this is the power supply I just ordered, will it suffice?
Kingwin Mach 1 1000W Power Supply Modular Cables 20/24PIN SLI Ready
DC OUTPUT
Output Voltage +3.3V +5V +12V1 +12V2 +12V3 +12V4 +12V5 +12V6 -12V +5
Max. Load 24A 30A 20A 20A 20A 35A 35A 20A 0.5A 5.0A
Min. Load 1.0A 1.0A 0.8A 0.8A 0.5A 1.0A 1.0A 1.0A 0A 0.1A
Regulation ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±10% ±5%
Ripple & Noise(mV) 50 50 120 120 120 120 120 120 120 50
Total Power 1000W continuous output @ 50C ambient temperature
phenom and tri sli, thats really different, but i think the psu should be fine just so long as you dont have all the plugs being used at one time
it will definetely suffice but you wont need the 12v lines for the most part... (sorry i was thinking about 4-pin molex, you will only need one of those strands of three)
im pretty sure if you wanted to you could have 2 bluray burners 2 dvd burners, and 6 hdds in raid 0 with that psu, i think youll be fine
I don't know if you combine or not, but I assume u do...
I just have a question someone can surely answer... How does that PSU work... isn't Watt = Volt x Amps ?
If so, just looking at the 12V there is 20+20+20+35+35+20 = 150
150A x 12V = 1800W ?
That doesn't make any sense here, can someone explain me this.
To get close to the amount of total amps on the 12V rail/s. You take the watts on the 12V rail/s and divide it by 12.
i really dont know, there is a power supply load calculator somewhere along the line, if you really want to go overboard go with a 1200 watt rosewill zeus or a pc power and cooling 1200w psu, i know those can hold your system
pal you'd be ok with a really nice 800W 1000W is crazy. and the odds of the actual computer using more then 400W is unlikely.
