M
mnplus1
Guest
i have a costom made computer and the crappy 180W power supply doesn't work anymore. i went onto xoxide.com and found a pretty good deal...
http://www.xoxide.com/assorted-power-supplies.html
i took some measurements and the power supply needs to be 6 in. is that one on the link going to fit? also does the power supply on that link have to wires attached or do i need to solder them? also does the motherboard connectors have a 20 plus a 4 pin connectors?
any help is appreciated!!!!
