Power supply problem or graphic card problem???
pcspte
i hav problem dunno whether causes by the low voltage supply or cause by my graphic card....
wen i not using the graphic card, the voltage indicator also showing warning...if really low voltage problem, wan to do?? any assist??
What exactly is the problem? What are the values of the voltages that your system is complaining about?
how can you not use your video card and see the warning? and if your card is overheating then error messages may come up... please state more clearly
oh..sorry......even i didn't plug in my graphic card the PC Alert indicator for 3.3V is 2.96V for my computer, wen i plug in my graphic card, my computer restart automatically wen i play games n open too many graphic program..
Sounds like a faulty/insufficient power supply. What are your system specs, and what PSU and video card do you have?
PSU is power supply. Take the side panel off your case and take a look at the power supply itself. On the label should be written a brand name, model, wattage rating, and amperage ratings for each rail, probably in a table for.
Tell is the brand and model , wattage rating and the amperage rating on the +12V rail.
eh....is 450W brand is icute
tat all i can see.... will it be not enough current??? i used my old computer dun hav tis error but my old computer is P3....
any clue??
