Power Supply starts and stops???
Marcus Madland
Power Supply starts and stops? makes the computer start and stop too. Just awhile ago my computer were running perfectly fine. I get it to start sometimes if I let it run for a hour.. but mostly it just turns on and off.
and when I finally get to start my computer non of the monitors works. Please answer! As I said, the computer worked perfectly fine a few weeks ago, was on holliday and i just found this issue, so nothing is wrong how I built the computer. Thanks! <3
Is this a custom built or pre-built machine?
Sounds like a typical case of a dying PSU.
Nvidia Geforce something
CX 750 corsair
inteli7-4790k
8x2 GB ram dont remember name atm
this setup worked so I dont think its something wrong with that..
Brand new build just a few days old? I would say grounding issue somewhere. Did you use the standoffs between motherboard and case?
I would try a different power supply first. If you are going to gone for any period time always unplug computer in case of power surge, storm, etc.
