P Phil11 New Member Sep 16, 2005 #1 need help with power switches how do u tell which connecter is + and which is - case is aopen QF50A mid tower Last edited: Sep 16, 2005
Johnnyboy0056 New Member Sep 16, 2005 #2 usually red is pos and black is ground/negative. but if both colors arent there, go with the one that is....example....if wires are blue and black....keep black as negative.
Archangel VIP Member Sep 16, 2005 #3 meh... on a swich it doesnt matter which one you take as + and sich one as - a swich simply shorts the 2 cables, so the 2 pinns of the pwr_swich are actually shorted (when you push the button)
Rip_Uk Active Member Sep 16, 2005 #4 i had that problem, on the rear of my cables i had a small triangle imprinted pointing to the positive
Praetor Administrator Staff member Sep 18, 2005 #5 how do u tell which connecter is + and which is - Click to expand... trial and error should work ... there's only two possibilities
