Pro Evolution Soccer 5 Problem - Please Help!
IronMan101
After a few minor graphics problems, i reinstalled my drivers and now I am unable to properly play PES5. I either try to load or start a match and a few seconds into the game i get this message:
I downloaded and installed the .NET Framework 3 and I reinstalled the graphics drivers again. At least now i am actually able to start a game, but i still get the same above error a few seconds into any match - the the game exits.
I used to be able to play it fine and I've already tried reinstalling. Any ideas?:confused:
The same sort of problem happens in different applications every now and then. Not near enough to bother me as much - but when it comes to games; this is the one that has the most problems.
I used to have kitserver installed and running (add-on kits, balls etc.) but i deleted it and reinstalled the game and it seems that kitserver itself (although buggy) wasn't causing the problem.
I'm wondering what your ram configuration is? (amount,type etc.) Perhaps you can go ahead and just post your systems specifications? Sorry, I should have asked for that earlier.
RAM: Corsair 2x 512Mb modules (Low Latency)
CPU: Athlon64 X2 3800+
GFX: Abit RX800 GURU 256Mb
I can also post a HijackThis log if you like, so you can see if anything is running that shouldn't be.
