CyberPilot
Hi guys,
i have a FOXCOMM 45CMX motherboard with 4 SATA connections and a single IDE slot. I am trying to connect a couple of old IDE hard drives (HD) but am having problems. I am tyring to connect a single one at the moment. I have set the HD pins to 'slave' and i have attached the slave IDE cable coming from the motherboard into the HD. The power cables are definitely working because i can hear the HD disk spinning. I have checked in the bios and in Windows, but the HD does not show up. This is a resaonably old HD (Maxtor 160 GB diamondmax plus 9, ATA/133). In the 'transfer mode' option, do i have to turn the DMA off in the primary and secondary IDE channel and use PIO only? Soooo confused, aaaaarrggghh !!! Thanks in advance.
Cheers,
Pete.
Cheers,
Pete.
