J Johnny24 New Member Mar 23, 2014 #1 After replacing a motherboard screen is acting weird, anybody knows what that could be? Thanks Attachments image.jpg 79.3 KB · Views: 59
johnb35 Administrator Staff member Mar 23, 2014 #2 Connect a monitor to the external vga connector to see if the lines are still visible. If not, then its something with the screen connection.
K kdfresh09 New Member Mar 26, 2014 #3 where did you get the motherboard replacement. to me, id say that the motherboard you installed has a bad GPU issue.
J Johnny24 New Member Apr 3, 2014 #4 kdfresh09 said: where did you get the motherboard replacement. to me, id say that the motherboard you installed has a bad GPU issue. Click to expand... Hi, so.. I connected it to external monitor and picture is fine, but my wifi and sound is not working, can it be related to screen problem? I bought my motherboard online, really don't know what to do now.
johnb35 Administrator Staff member Apr 3, 2014 #5 Most likely need to install drivers for sound and wifi.
J Johnny24 New Member Apr 3, 2014 #6 johnb35 said: Most likely need to install drivers for sound and wifi. Click to expand... Yeah, but my concern is the screen, I need to fix it somehow..
johnb35 Administrator Staff member Apr 3, 2014 #7 Either a bad screen or something with the cable connection.
J Johnny24 New Member Apr 3, 2014 #8 johnb35 said: Either a bad screen or something with the cable connection. Click to expand... I was checking the cable, so it looks like when I'm touching cable where it bends around the hinge it's getting worse so I guess it could be the cable Last edited: Apr 3, 2014
