computer-bot
Hi Guys. Well I am facing a weird problem from the last couple of months. Two three months ago I had installed Linux (Fedora core 2) on my system along with XP. Then I formated the drive which had fedora on it. Soon after that format, when I reinstalled my Xp back, I started to face problems with my XP. The problem was that when I used to lock some of my folders with folder security, my recycle became inaccessible. Also my combo drive wasn't responding properly , meaning when I insert a disk, it doesn't show the name and icon of the disk on the CD drive icon in my computer unless I restart my computer. This surely is not a big problem but the problem arises when I am burning a CD. Every time I try to burn a CD I have to first insert an empty CD and then restart my PC before it starts reading that CD as an empty CD otherwise the OS says that there is no empty CD in the drive. The I formated my computer completely and fixed the MBR. After that I reinstalled my XP and the system was working properly but recently it had began to show the same symptoms and this time it's even worst. Now a days when I try to install a software, it takes about 10 - 15 mins to go through the initial few windows (where it prepares the install shied and the rest of the stuff). Please can someone tell me how can I fix this problem without formating my hard drive. Also I have five partitions on my Hard Drive.
c: Fat 32 (5 GB)
D: Fat 32 (7 GB)
E: Fat 32 (5 GB)
F: NTFS (55 GB)
G: Fat 32 (2.5 GB)
Is it OK to have an NTFS between two FAT 32. (Just curious)
CB
c: Fat 32 (5 GB)
D: Fat 32 (7 GB)
E: Fat 32 (5 GB)
F: NTFS (55 GB)
G: Fat 32 (2.5 GB)
CB
