Problem with RAM ... need some help
RAD6774
Ok, my mobo is a MSI KT6V, AMD Athlon 2100+ XP Processor .... anyway i have had this comp for some time now and i have always had 2 sticks of PC2300 512mb. Well my mobo only has 2 slots of RAM and to upgrade to 2GB of RAM soon I bought a 1GB stick to replace my x2 512MB sticks. But with this new stick when i get into windows and start doing things everything freezes up, then i have to restart. It wouldnt quit doing this so i put my 512sticks back in and everything works fine. And yes i am sure my mobo supports 1GBsticks. Here the specs of my mobo to see for yourself. http://www.msicomputer.com/product/detail_spec/product_detail.asp?model=KT6V-LSR Also i am sure its the right RAM (pc3200, sticker says * 1GB, DDR DIMM, Q*)
So i'm not to sure of what is going on here but if someone can explain how i can make it work or if its just a bad stick of RAM, i hope its not bad seeing as how i paid $85 for it.
Heres what your mobo states
• Supports DDR400/333/266/200 SDRAM
Heres your RAM
PNY Optima 1GB PC3200 DDR DIMM Memory
hmmm your RAM is DDR 400 so this is rather strange.
ohh power supply.. that just came to me, as far as i know its working fine. Its a 350Watt and it came with my case (made by Antec)
well i have "MSI live update" that checks my drivers and stuff, when i started using it, it had a BIOs update so really thats the biggest update i have done to it, the rest of the stuff is program updates.
Ok make sure you have al the updates.
Ok what is your 512x2 RAM speed? 400mh? Also your mobo has 4 memory slot banks so why take out your 512x when you put in your new 1GB?
well i just did a search for driver updates and it didnt help.... the only thing i can think of is something isnt set right in the BIOs... and thats one area i dont like to mess with cause i would rather not kill something.
No i only have 2 slots for RAM... idk why it says that. and yea my old RAD in 400MHz just like this new stick.
That is strange why it wont work. Like I said it might be the PSU.
Yea this is very strange ..... next time i go to a LAN or something i will switch power supplies with someone to see if thats it, if not then i guess i dont upgrade the RAM 0_o ... well thanx for ur help.
