Problems connecting to monitor...
tenox
banned
Hi !
I newly bought all new parts to set up a new computer. When i was finnished i could not get a picture on my monitor. The computer obviously have problems connecting to the monitor. I checked out with another monitor, but that didnt work either. It is extremly frustrating, because i have never been into this problem before. Do anyone know what the problem might be?? And how i could fix it?? I would be extremly thankful !!
Thanx
Steffen
Hi, thanx for your attention !
Here is the list of the components :
Grafikk : Sapphire X800 XL Pci-express
Harddisk: Samsung SpinPoint P120S 200GB SATA2 8MB 7200RPM NCQ
Motherboard : Asus A8N-SLI, nForce4 SLI,Socket-939 ATX,S-ATA, GbLAN,Firewire,DDR, PCI-Ex16
Prossesor : AMD Athlon 64 3500+ 2.2GHz Socket 939, 512KB, BOXED m/vifte
CD/DVD :
Sony DVD-spiller IDE 16x/40x Sort Bulk, DDU1612-B2
NEC DVD recorder ND-3540A IDE Black OEM DVD+R/+RW/DVD-R/-RW (Dual layer)
Memory : Corsair Value S PC3200 DDR-DIMM 1024MB Kit w/two matched Value Select 512MB
I hope this would help you guys !
And thanx Again !!!!
