Problems Problems, help
Talon010
hi everyone i signed up here to ask this question and will prolly find other forums to ask this question. Tonight i jumped on my computer to socialise on msn messenger and my space and they just didnt work...sounds weird yeah, just like that just decided both to stop working. i use mozilla but it also didnt work in internet explorer or on my other networked computer. I found that most sites worked but www.myspace.com, www.skateboard.com.au, www.urbandictionary.com and www.hotmail.com did not work, it came up with this:
The connection was reset
The connection to the server was reset while the page was loading.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the W
strange how those sites dont work but most others do work...i tried turning off my antivirus/firewall stuff and it did nothing. I scaned my whole hard drive for virus' and got a fue lol but I deleted them all and it didnt make a difference.
And msn does work on my other computer but not on this one, which is the one i mainly use for the internet it says signing in for a while then comes up with this message:
Signing into msn messenger failed because the servise is too busy. Please try again later
yet it works on my other computer? dosnt make scence if the server is busy...
very weird problems for me.... Someone PLEASE help me!
Thank you
-Jesse
I have had a few problems with MSN also in the past, for me its simply unreilable, I think the problem arise when you sign in at a different location the go back to the one you normally use.
