Hey,
Well my problems with my older computer started in september, when installing it in my new home. When I started it, it would go up to the Windows welcome logo then will reboot, doing that over and over.
So I tried to fix it, did system restore. It worked fine until I installed the drivers for my wireless antenna card. It shut down and did the restarting over and over. So I decided to buy a new card thinking the hardware was broken (it was pretty old...). System restore again, installed the new wireless card. Everything was working fine until I updated WinXP and it started again. So I did system restore again and now decided to run my computer with no WinXP updates.
Anyone had the similar problem? Any ideas on what the problem is??
PS: My WinXP is totally legit.
Thanks for any help
Thanks for any help
