Manakore
I have the asus crosshair iv formula motherboard, and the tempest evo case. The fans that came with the case connect to the 3 pin connector on the motherboard. However, there are male and female molex connectors attached to the 3-pin fan cable. Do I have to use my power supply cables to plug in the molex cables as well, or will the three-pin connector plugged into my motherboard do the job? Thanks.
