Really serious problem! Plz help!!
MaNiC MoE
ppl, 1st of ll, this ain't my computer and I destroyed it!
Seriously, I mean it
I wanned 2 install internet expolrer 7, so I validated the PC and it said it wasn't Geniune, so I used a crack tool (that I used a lot and it works). However, I misread the instructions. It said to either restart the computer or install a registery, so I did both!!!
Now the explorer doersn't wanna open at all!!!! :o :o :(
What can I do, I copied the registery on my own PC that was changed, shall I restore it??
pleeeeeeeeeeeeeeze, I'm desprite 4 help!!
thx
Well, discussion of cracks is against Forum Rules, so I really don't think we can help you with the crack, however I might recommend trying to restore to an earlier point to fix whatever registry problems you might have.
We don't know what to do or help you, and probably your stoopid crack broke down IE7 , thats logic, now to the front page and READ the RULE
