recommend a power supply for my system, please!
Beyond
dfi ultra-d
2gb corsair xms
3800+ x2
7800gtx
raptor in the future
i realized my power supply that i planned on using isn't what i thought it was .. 350watts .. 12a on the 12v rail. i'm thinking that def. won't do?
i was looking at this psu:
http://www.newegg.com/Product/Product.asp?Item=N82E16817148001
looks good to me, however i don't want to spend nearly that much. would you recommend that psu?
what other power supplies would you recommend, ideally cheaper than that?
Amps look good... does it have the cables you need? Also check reviews for stability and noise and stuff.
i was gona get that, someone told me its a no go. there not great i guess.
well i wouldnt cheap out either! if you got a 400$ veid card and cant buy a 100$ psu?
get the NEO he the one i have. i love it.
500w ultra x-connect or x-finity psu can be found at a relatively good price at frys and look pretty good. I got my x-connect for about $35 after rebate. It works great with my setup but the uv lighting stopped working.
PSU 101
I wouldnt for a power box like that. On older ATX1.03 spec boxes hell ya but not that
