Remote Desktop Connection problem!
NOOBIE
i have 2 computers hooked up to a netgear adsl router and i am trying to make a remote desktop connection work but i cant everytime i try to make one it says "the client cannot connect to the remote computer" i have tried it on both pc's i get the same result on both and when i go to browse for more in the remote desktop connection it says "the MSHOME domain/workgroup does not contain any terminal servers, the computers are both on the same workgroup and everything else in the network works fine like file sharing and multiplayer games :confused:
you need to enable remote desktop connecting on the target computer
do you still need help with this? or have you gone to the other client? I think that I might be able to help you out.
