Senior Capstone Project-Need Help
JTM_Unlimited
I am trying to determine what project I should pursue for my capstone project. Basically, you define a problem, and now out of my theoretical problems, I need proof that it is a very widespread problem. Here are some of my potential problem statements:
Don’t you hate it when you wrist/hands get hurt after using a mouse or controller for an extended period of time?
Don’t you hate it when your headphones or headset put pressure on your outer ear, causing pain and damage after an extended period of use?
Don’t you hate it’s hard to keep track of all your equipment at LAN parties
If you guys could give me your feedback with the following surveys, I would really appreciate it (note: its a safe website, the school pays for the license, and there is no spyware or anything like that).
Mouse Problem
http://www.surveymonkey.com/s/YNLNN63
Headset Problem
http://www.surveymonkey.com/s/YNSFYNH
LAN Equipment Problem
http://www.surveymonkey.com/s/YWBWY87
Thanks for helping out guys, if you want you can look up the status of our project at wiki3.niskyschools.org/wiki/pages/F2R7s8N1s4/JTM_Unlimited.html
got the headphone and mouse issues. they have some rubber pad things for my issue with mice where my rist is on the corner of the glass so it is almost cutting it so it hurts. for the headphones i have the cheap on-ear headphones from turtle beach so after a few hours it has partially flattened my lobes and hurts like hell if i touch them, really annoying.
