K K-Dawg New Member Jul 3, 2004 #1 Whenever i want to play Warcraft 3 Frozen Throne, the sound does not work, so i do not get the full effect of the game. My sound works fine otherwise.
Fure6 New Member Jul 5, 2004 #2 Have you checked if your game supports that sound card? Only thing my little brain can think of. . .
K K-Dawg New Member Jul 5, 2004 #3 Well when i first got the game it worked good, but now all it does it play the backgrond music, so i dont get the weapon clashing effect
Sin Adam New Member Jul 6, 2004 #4 u might be able to find the solution at blizzard's website. http://www.blizzard.com/support/?id=mwr000p go to that link. Video and Sound Issues should be at the very bottom
M mainseat2004 New Member Jul 9, 2004 #5 Did you unsetup your Sound Card software? if , then resetup......
