Strange fan scraping noise...
CPU2
Basically...my mouse cord tends to get disconneted if i accidently throw my arm around when im to liberal in my gameplay. The connecter in the back of the tower tends to get d/c...
I used to grab the cpu, tilt it and balance it on its bottom corner to get an easy grab for the connector in the back...to easily adjust the cord, well I did it about a week ago and i got a strange fan scraping noise inside the cpu...i quickly pulled the tower back into its normal vertical stance and the fan went right back into spinning without issue.
Im just wondering what fan it was...video card fan, or maybe the regular cpu fan?...i have no clue, im just wondering if there's SERIOUS issues that can come of this...or is the lesson here, "Dont **** with the tower and lean it anywhere..just leave as it is and nothing will go wrong".
I dont ever get the issue unless i lean the tower...so i dont touch it at all, im afraid of messing it up lol.
You probably got a cable stuck in a fan. Just open the case up and tilt it around and then tuck away whichever cable it was.
And no, your PC won't break. If a cable gets stuck to the point that it could cause damage the fan will simply stop rotating.
