system unit overheating...
arnel222429
one of my PC is overheating...i suspected its a power supply failure...i bought a brand new one which is 650W, then i try it to Turn-on after 15 min still the same...what's the problem in here!? please help techpeople..they said it is the power supply some are video card and processor..please help me what is the cause of this..please
check to see if the cpu fan is working, i would suspect that to be the first one to go, try it with the side panel off, to see if any fans aren't working
i chek the cpu fan and all the fan..but it's still the same..after a minute it starting to heat..i clean it up always..because i know dust=no..but i dont no whats going on...please another advice..
Reseat the CPU heatsink, there could be a contact problem. Make sure you use arctic silver 5 or another high quality thermal paste.
the thermal paste suggestion is very good from the friend above :P so i will not repeat it, but i wanna tell you that after you replace the thermal paste with an newer - high quality one, if the problem fixed, then you're sure that the problem was CPU' overheating. To solve this once and for all my suggestion is 2 good fans, one for input and one for output air, and a good WATERCOLLING SYSTEM!! :P
thanx for the advice..i try to go to BIOs and see the CPU temp and i see it goes 60 what is the normal temperaure?range 30 to 40?..please help...
