these parts work good for first PC?
Lando454
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800),
CORSAIR CX series CX500 500W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply,
Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive,
ASUS M5A97 LE R2.0 AM3+ AMD 970 + SB950 6 x SATA 6Gb/s port(s), gray USB 3.0 ATX AMD Motherboard with UEFI BIOS,
AMD FX-4350 Vishera Quad-Core 4.2 GHz Socket AM3+ 125W FD4350FRHKBOX Desktop Processor, and
MSI GeForce GTX 750Ti GAMING N750Ti TF 2GD5/OC 2GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card.
What specific budget do you have? That's kind of a low end build as we approach 2016.
Hold off until Black Friday and then see what you can build with your budget. You'll be much happier getting a better CPU/GPU and not having to upgrade as much in the future.
yes will be buying parts on black friday most likely. Not a low end PC for what it is going to be used for (garry's mod, borderlands, and counter strike). this is not a hardcore PC by any means this PC will be used by my entire family all my hardcore gaming like fall out and FPS games will be on xbox one. Just needed to know if all the parts will work.
Try to get a 990 board of you can, since they're a bit newer. Since the price difference is very little, for your original budget you should be able to get much better parts (FX-6300 + GTX 960/R9 290). For $450 I built a Athlon X4 860K & R9 280X system.
Prices always drop substantially. Just keep your eyes peeled :)
