THX TruStudio pro "audio device not supported"
Eblermeister
Hey.
I have laptop from a company called XNB.
When i got my laptop, it had a program called THX TruStudio pro.
One day i reinstalled windows and all of the drivers - after this THX TruStudio pro started saying that it was unable to detect a supported audio device "audio device not supported" - when i open the program, all of the buttons are grayed out and nothing works.
I am just using the laptop speakers (realtek)
How can i fix this?
Thanks in advance
Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
16 gb ram
Intel(R) HD Graphics 4000
Nvidia, gtx680 m
Could you please try updating the driver manually from the official website? Or by using Device Manager's update driver?
Alright. Uninstall the Realtek drivers by using Device Manager and reboot your laptop. The New Hardware Found wizard should start up. Insert the DVD provided by your laptop vendor and select to install the driver manually and set the location to the DVD. After installation, try rebooting and using THX TruStudio pro.
Okay, i will try that :)
I have two that i can remove:
"Realtek High Definition Audio"
and
"Speakers (Realtek High Definition Audio)"
Which one should i remove?
