dak1b
Update PC Power & Cooling S75QB 750W ATX12V / EPS12V Power Supply
Model
Brand PC Power & Cooling
Model S75QB
Spec
Type ATX12V / EPS12V
Maximum Power 750W
Fans 1
PFC Active
Main Connector 20+4Pin
+12V Rails Single
PCI-E Connectors 2 x 6Pin, 2 x 6+2Pin
NVIDIA SLI Support NVIDIA SLI Certified (Dual 8800 GTX and below)
ATI CrossFire Support Yes
Modular Cabling Support No
Power Good Signal 300ms
Hold-up Time 16ms min.
Efficiency 83%
Energy-Efficient 80 PLUS Certified
Over Voltage Protection +3.3V, +5V, +12V
Input Voltage 100 - 240 V
Input Frequency Range 50/60 Hz
Input Current 12A
Output +5V @ 30A
+12V @ 60A (Powerful Single Rail)
-12V @ 0.8A
+3.3V @ 24A
+5VSB @ 3A
MTBF >100,000 Hours
Approvals UL, ULC, CE, CB, RoHS
Features
Connectors 1 x Main connector (20+4Pin)
1 x 12V (4Pin)
1 x 12V(8Pin)
8 x peripheral (4Pin)
6 x SATA
1 x Floppy
4 x PCI-E
Features 750W Continuous @ 40°C (825W Peak)
Up to 90% (10dB) Less Noise per Watt
NVIDIA SLI Certified (Dual 8800 GTX)
High Efficiency (83%); .99 Active PFC
Rock-Solid, Super-Clean DC Output
Automatic Fan Speed Control Circuit
Manufacturer Warranty
Parts 5 years limited
Labor 5 years limited
Introduction
With all the processors, cards, fans, add-ons and being added to systems today, it's harder to find the power to you need without overheating! Your relief has arrived! Here's extreme PC power & cooling performance and reliability, with 750W of continuous power and a peak power of 825W!
It features a powerful single 12V rail rated at 60A continuous. The ultra-quiet cooling design leaves the inlet wide open, so 90% less noise is generated per watt with an impressive 83% efficiency. The active PFC (.99) neatly handles input sags and surges and eliminates the need for an 110V to 220V input switch. Automatic fan speed control minimizes noise without sacrificing proper cooling.
This power supply has a 24-pin main connector, a 4-pin 12V connector, an 8-pin 12V CPU connector, 8 peripheral connectors, 6 SATA connectors, a floppy connector, and two PCI-E connectors, two 6-pin to 8-pin PCI-E connectors. The Silencer 750 Quad is NVIDIA SLI and CrossFire certified. This economical, ultra-quiet power supply is backed by a 3-Year warranty and support.
Highlights
EPS12V Compatible
Compatible with the EPS12V standard, the PC Power & Cooling Silencer 750 Quad power supply provides maximum power stability to drive the latest Intel and AMD processors as well as other components for desktop and even sever computer systems.
750W Maximum Power
The PC Power & Cooling Silencer 750 Quad power supply provides a maximum power of 750W for a safe, reliable output for high-end computer systems.
Featuring four 6-pin PCI-E power connectors, the PC Power & Cooling Silencer 750 Quad power supply has gone through a series of rigorous NVIDIA SLI certification tests for maximum system stability when building NVIDIA SLI PCs.
ATI CrossFire Certified
The PC Power & Cooling Silencer 750 Quad power supply has gone through a series of rigorous ATI CrossFire certification tests for maximum system stability when building CrossFire Ready multi-video-card PCs.
Ultra-Quiet Cooling Design
The PC Power & Cooling Silencer 750 Quad power supply employs an innovative, ultra-quiet design at the inlet side of the PSU fan for minimized air turbulence. By constructing a noise suppression air gap, no air turbulence and obstruction exist within 1" at the fan inlet, resulting in an ultra-quiet operation.
Photo Gallery
Quick Specs
Maximum Power 701 - 800W
Efficiency > 80%
Fans 1
PFC Active
NVIDIA SLI Support Yes
Detailed Specifications
Learning Center
Power Supply Buying Guide What Is a Power Supply?
Power Supplies Types/Form Factors
Things to Look For When Choosing Your Power Supply
Our Recommendations
View All Learning Center information on Power Supplies Category»
Whats ur guys feedback on this??? thanks
Model
Model S75QB
Spec
Maximum Power 750W
Fans 1
PFC Active
+12V Rails Single
Efficiency 83%
Input Current 12A
Output +5V @ 30A
-12V @ 0.8A
+3.3V @ 24A
+5VSB @ 3A
MTBF >100,000 Hours
Features
1 x 12V (4Pin)
1 x 12V(8Pin)
6 x SATA
1 x Floppy
4 x PCI-E
Introduction
Highlights
EPS12V Compatible
750W Maximum Power
Photo Gallery
Quick Specs
Efficiency > 80%
Fans 1
PFC Active
Learning Center
Our Recommendations
