Upgrading an HP 6475Z..will these parts work/fit?
PcFreak14
well i have this pc..an HP 6475Z..heres the specshttp://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&docname=bph04788&lc=en
And for christmas/ birthday i was thinking doing some more upgrading..this is what i already did
Upgraded parts-
Screen-15in LCD
Operating system-installed Windows XP PRO
But im not sure if this case will work?
http://www.bestbuy.com/site/olspage.jsp?skuId=6801339&productCategoryId=cat01069&type=product&cmp=++&id=1091099928385
im also going to ask for a 80 gig internal HD
Also a stick of 256MB of memory..either from bestbuy/circuit city
**Its not goin to be a gaming pc as you can tell just a basic/ fast music and internet pc for my room..any help suggestions..THANKS SO MUCH steve
You cant upgrade a case since the parts in your HP are specially designed to fit an HP case, and dont buy one at BestBuy. You can get a very similar one on newegg for around $30.
For the hard drive, make sure you get an IDE and not a SATA.
As for the memory, make sure that its PC100. And your PC has a maximum of 256MB, so you couldnt use your 96MB in addition to it.
