Using a wireless card or Ethernet connection?
Justinator
Is using a wireless card just as stable for gaming as using a wired connection?
I am upgrading to Fiber optical internet now that it is available on my street and I wondered if I should use the old wireless card from my old PC or if I should use an wired connection for gaming.
For gaming your usually much better off using a wired connection. :)
i use wireless for my online gaming and i have no problem it. but in file transfer it give me a headache...
You probably won't notice much of a difference if you have good signal strength on the wireless. You'll likely only see a difference if you're sharing files between systems, as the wireless isn't as quick.
