using Power-point, need help asap
ChrisDVD
Hello
I'm doing a school project with power point. it is about 'building your PC'
what i do, is i put like each page a choise, for example, the amount of RAMs, the processor, Hard drive, disk drive, speakers, etc. i will like that the viewer choose what he gets. So by clicking on somethin (perhaps a shape) thepresentation will remember everything he cleiked, so at the den, it will show what he has. do you know what i'm talking about?
ok, if you do...how do you do that?
Chris
ChrisDVD said:
Hello
Chris
I dont think you can do that in power point. Maybe you can screw around with HTML.....
right click on the object and select action setting
and there are some options that will help you
EDIT: btw i like your idea
i just finished this year at college i might wanna do something like this (not exactly) next year
i hope you dont mind :D
Hey, no, i dont mind! thx for yor help....i will try that :D
Chris
