V. Weird Problem Need Help!!!!
Fisher
Please bare with this, I know it is long but a lot of weird things have happen up to its death!!
Computer specs:
The comp is less than 6 months old
AMD Athlon 64bit 3000+ Winchester 939 socket
1G Corsair pc3200 ddr400
Connect 3D Radeon x850 XT PCIe – only had since June 26th
MSI ATI RX480M2 motherboard
Hiper 525w 12v Low Noise PSU
DVD writer
Floppy Drive
Memory Card reader
Three fans
120 G sata hard drive – C:\
Two 250G hard drives (Storage), one sata (not on raid), one IDE
USB Sound Blaster audigy 2nx
Windows xp home edition
Nothing Over-clocked
This problem started when my computer was on over night in which there was a power cut. Turned it on the next morning played call of duty UO online and noticed it started to lag after a while. Closed down cod and noticed my comp was being very strange:
• Could not open icons on the desktop, had to right click and go to open.
• When writing down the symptoms in note pad the icon where you’re writing was rapidly blinking
• When playing mp3, it was like it was skipping
• The strangest thing is the computer clock. A minute would tick away about every three seconds. It would get to around 03.45 and then go back to 02.35.
• Pressed Ctrl Alt and Del had a look at the performance and the CPU was going up and down from 15% to 25%.
It was like the computer went into overdrive
It would go back to normal when I reset the comp but would soon start again when I played a game.
Scanned all the hard drives using Norton Antivirus 2005. Nothing found
Scandisked the C:\ drive no problems
Re-installed the sound drivers and video card drivers. Still happened again when I played COD
A couple of times it would not start properly, it would not even show any thing on the screen or it would get to the Windows XP load up screen and would lag out
THEN!!! It appeared to have sorted it self out. Played COD ok and everything. Until one morning when I turned it on. Got into windows fine. But then went very slow, so slow that it had a hard trouble opening up a menu. Came up with a box saying that the VPU on the graphics card has recovered from an error. Reset the comp and then it wouldn’t start. Left it a bit, it started up fine, loading up windows fine and then it just cut itself out. Left it until the next day. Started up fine again until it got to the Windows xp load screen and cut out again. From then on it will not start.
I have my suspicions on the graphics card but would like some expert advice as I’m only an amateur enthusiast.
Yeah, it sounds like the graphics card got a power surge or something when the power went out. Probably going to have to get a new one to resolve the issue. (It almost sounds like a memory leak that is on the card itself...)
Thank you, I have posted this on some other forums and this is probably one of the most senisble answers i got about the graphics card. Could you give me an explaination about why all that wierd stuff happened in the beginning, (espiecally the part about the CPU jumping up and down form 15% to 25%)
Thank you very much
I think im going to have to ring savastore.com up and get them to replace it for me
well, to help dciscouts out a little bit, the memory on the video card could have slowly leaked from the electrical jolt it took from the power outtage, meaning the more the card was used after the damage the worse it got because of the demand put on the card. as far as the cpu jumping from 15 to 25%, this could simply be from the inconsistency in the memory on the vid card.....makes the most sense....get a new vid card and check it out...good luck.
Well firstly, thanks for the very detailed pre-analysis. one thing you can have a look into is the thermals for the videocard... the ATi drivers should provide thermal management option... if not, RivaTuner does ... with Rivatuner, you can even check the voltages for the videocard
Another thing to check is the voltages on the rest of the system... something like SpeedFan or Motherboard Monitor 5 will allow you to monitor that.
